finned aluminum valley cover
The finned alum valley I had could not be installed without removing one or two heads. I cant remember which because it was a long time ago. Also, it is usually the case that the oil fill pipe and hole has to be installed by buyer. I had the installation done by a machine shop, and it didnt fit correctly, interfering with the thermostat housing and required material removal from the housing. Ended up throwing the damn finned cover in the trash.
Somewhere, there were pictures posted about how one person machines the cover to provide clearance in the 4 areas where the ports are, so the cover can be installed without having to remove the heads. Naturally, one could do the same thing with the proper file and turn in a nice version, if accompanied by the proper workmanship.
I can't recall where I saw the pics -- sorry.
