AC question
Old May 29, 2007 | 10:23 AM
algorythm's Avatar
algorythm
AC question
I just replaced the AC clutch on the truck since it was making noise. The AC does not blow cold air which I would suspect that there isnt enough coolant. One thing I did notice, however, is the you can hear the AC kick on then quit in a couple seconds, then on and off again. Not enough time to build up some pressure. Any ideas why it would kick on and off so quickly?
Old May 29, 2007 | 10:26 AM
Bruce R Leech's Avatar
Bruce R Leech
what are you working on?
Old May 29, 2007 | 10:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Possibly a bad A/C compressor "Kicker" switch. It's shorting out (common) and that's why the compressor is turning off and on.
The kicker switch for the compressor clutch is located under the dash above the a/c heater control panel...it mounts to the: Air Conditioning Vacuum Selector Valve Assy (19B888). This is a multi ported vacuum manifold that besides having the kicker switch, controls vacuum to the blend door motors. Available from Ford.
Jacobs Daddy
May 17, 2012 02:46 PM
rideracelivemx7
16
Jul 1, 2011 07:00 PM
MPohl
1997 - 2003 F150
Jun 15, 2011 09:48 PM
Aggie05
Bronco II
Jun 16, 2007 06:07 AM
Zoltrix
1997 - 2003 F150
22
Oct 2, 2006 07:18 AM
