General Automotive Discussion
Sandblast Aluminum Rims?
Old 05-29-2007, 08:28 AM
Bruker's Avatar
Bruker
Bruker is offline
Question Sandblast Aluminum Rims?
I have a set of aluminum rims off a Jeep that are corroded pretty bad. I'm thinking about trying to refinish them by first having them sandblasted enough to remove the clear coat and corrosion then having them painted. Has anyone here ever done this?
Old 05-29-2007, 01:13 PM
bigrigfixer's Avatar
bigrigfixer
bigrigfixer is offline
The Pacifier
I think that's what wheel refinishers do. Then they sand it so pitts don't show up. Not like you can put bondo on a wheel.
Some refinishers will just sandpaper the whole thing, skipping the sandblasting. Takes longer, uses more.
Old 05-29-2007, 05:21 PM
ckal704's Avatar
ckal704
ckal704 is offline
I might be wrong, but I thought I read somewhere in these forums that sandblasting aluminum rims can increase the likelihood of a stress fracture or something like that.
Old 05-29-2007, 05:49 PM
1982_f150's Avatar
1982_f150
1982_f150 is offline
DONT SAND BLAST!! it will pit and look like crap. its called beadblasting. its for aluminum. go to your local powdercoating shop they will do it
Old 05-29-2007, 10:45 PM
ag30265's Avatar
ag30265
ag30265 is offline
You could always get some "zep-a-lum". It's an acid for aluminum and works very well, a couple of coats and pressure washing will make em shine good and remove the corrosion. Might be tough to get ahold of in small volumes, it's an industrial solvent but it works great.
I find using that and then when dry, use mother's alum polish and bring the shine back out in it, works very well.
If anyone go's to find the chem. I'm talking about, be careful, it is an acid and will eat you up. It hurts alot in the eye and when you let it sit on your hands and skin for alittle while, it will remove the clearcoat from aluminum, along with grease and/or other foreign objects on the material. Speaking from experience, it will also eat the plutonite coating off of good sunglasses.....remove the oakleys and wear safety glasses. Also makes an aluminum intake shine like a mirror.
Old 05-30-2007, 09:15 PM
F350-6's Avatar
F350-6
F350-6 is offline
Muriatic acid should also work to clean the rims and it's available at the local hardware store. Just remember any acid will remove a clear coat and will require a wax or polish to keep from dulling.
jimd1050
1999 to 2016 Super Duty
07-23-2015 01:43 PM
49 ford fire truck
Ford Truck Parts for Sale
04-09-2015 01:32 AM
egg collector
Paint & Bodywork
01-10-2014 11:43 PM
6863m
04-22-2011 10:55 PM
Schoonie48F2
Paint & Bodywork
10-28-2003 04:48 PM
Quick Reply: Sandblast Aluminum Rims?
