unknown error code
Old May 28, 2007 | 02:53 PM
Big Fish's Avatar
Big Fish
unknown error code
My code reader shows a code P0299 on my '05 6.0 SD, but I can't find that code in any listing. Anyone know what the code is?? cw
Old May 28, 2007 | 03:36 PM
Mark _G's Avatar
Mark _G
I got that code also. Ended up with a new turbo. I think it's a low/high boost for over 30 seconds?
Mark
Old May 28, 2007 | 03:39 PM
Mark _G's Avatar
Mark _G
https://www.ford-trucks.com/forums/5...ode-po299.html
Old May 28, 2007 | 10:49 PM
Big Fish's Avatar
Big Fish
Thanks guys, have had abnormally high boost when first starting out. Sometimes lasts a couple miles, sometimes more. Really sucks fuel when this happens. Heading for the dealer tommorow.. cw
Old May 29, 2007 | 05:41 AM
Mark _G's Avatar
Mark _G
Good luck. I hope your dealer treats you as well as mine did!
ark
Old May 31, 2007 | 10:20 PM
Big Fish's Avatar
Big Fish
Well, I guess that code means you get a new turbo, at least that's what my dealer says. Don't know just what it was for sure but that's the story. I'll learn more when I pick it up tomorrow. cw
Old Jun 1, 2007 | 12:28 AM
blackhat620's Avatar
blackhat620
Code P0299:
Turbo Underboost. Fault sets when the difference between EP and command EP exceeds the limit for >30 seconds.
This can be do to:
Faulty EP sensor,
VGT control valve slow to respond,
Stuck VGT valve,
Faulty PCM
Hope this helps
Old Jun 1, 2007 | 04:23 PM
Big Fish's Avatar
Big Fish
Noticed overboost, usually before engine was completely warmed up. Trans. didn't want to shift when boost was very high. Anyway, mechanic suspected sticking vanes in tubo, which turned out to be the case, but bearings were also out of tolerance. Now have new tubo. cw
