Engine surging......
Old May 26, 2007 | 09:48 PM
PLC7.3's Avatar
PLC7.3
I was looking through my scans yesterday and came across a TSB on engine surging when driving....... I have seen several posts re this problem recently. The TSB basically reads the Engine temp switch could be the problem as it will inadvertently send power to the Timing advance solenoid which will cause the timing to change thus surging. Fix is replace the Engine temp switch....
How would you know...... I would make a long enough wire with a bulb attached, hook it to the solenoid connector and the spade terminal..... make the bulb visible with the hood closed while driving....... if you get surging and a lit bulb then ....... Bingo.
Old May 27, 2007 | 07:05 AM
Cuda_jim's Avatar
Cuda_jim
Maybe this will help:
https://www.ford-trucks.com/forums/6...2-000-rpm.html
Old May 27, 2007 | 07:54 AM
PLC7.3's Avatar
PLC7.3
Sorry Cuda we don't have any of that new fangled CPS, HIpop stuff........we run bare bones engines......
Old May 27, 2007 | 02:50 PM
Cuda_jim's Avatar
Cuda_jim
Opp's I missed the 93 part. I hate when that happens, more beer!
I miss my old 6.9, may she RIP.
Old May 27, 2007 | 07:53 PM
PLC7.3's Avatar
PLC7.3
You are forgiven...more beer you bet pal.......
Tim Hodgson
1978 - 1996 Big Bronco
Jan 6, 2015 12:43 AM
njkite51
Apr 15, 2011 09:13 AM
deercreek1
May 4, 2010 07:48 PM
captchas
Modular V10 (6.8l)
Apr 9, 2006 11:02 AM
