Converting 302 Bronco to 351 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 10-31-1999, 04:42 PM
Brent
Brent is offline
Brent is starting off with a positive reputation.
I have an 89 Bronco with which I would like to swap out the 302 for a 351. It seems like it should be fairly straightforward. What I would like to know is: Are the motor mounts the same? Will the accessories bolt on without problems? Do I need a new computer (I have speed density)?
Thanks.
Old 11-04-1999, 12:21 AM
Superdave
Superdave is offline
Superdave is starting off with a positive reputation.
Brent, I think this is a direct swap mount wise, but your engine should be from a 4X4 F-150 or big Bronco.( it would just be less hassle ) Your Bronco has the AOD trans dosen't it? The 351W picked up the AOD trans in 89 I believe. And you probably will need the electronics from the donor vehicle. I don't know about the accessory brackets interchanging.
Old 11-06-1999, 10:57 PM
Mulletwagon
Mulletwagon is offline
Mulletwagon is starting off with a positive reputation.
Since the heads sit up on the block higher on a 351 compared to a 302, any 302 bracket that is attached to the head and the block or water pump will not fit on a 351. You really want a 351 that comes with the brackets if possible. Don't know if oil pan shape will be a factor (Bronco pans use to be different -rear sumps- than car pans), however, 302 and 351 pans are not interchangable,i.e., you may need a Bronco 351 pan. Everything else should be a bolt-in. Once put a 351 in a 65 Mustang that had a 289 - great swap !! Good Luck
Old 11-09-1999, 09:43 AM
Phillip Guidry
Phillip Guidry is offline
Phillip Guidry is starting off with a positive reputation.
torque head
02-26-2011 11:52 PM
Dr.B
05-12-2008 08:08 PM
JCastellaw
08-16-2006 03:21 PM
cap4004
Engine Swaps
08-09-2005 10:05 AM
cheetha94607
07-18-2005 02:20 AM
Quick Reply: Converting 302 Bronco to 351
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
