1990 5.0l Bronco idling problem - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 10-26-1999, 07:32 PM
91Bronco
91Bronco is offline
91Bronco is starting off with a positive reputation.
Old 11-09-1999, 03:45 PM
lonewolftom
lonewolftom is offline
lonewolftom is starting off with a positive reputation.
I recently bought a 1990 Ford Bronco with 83,000 miles on it. It was maintained but has a odd problem with idling. It will start even in cold weather at high idle, but when it drops down it stalls out. After a restart it will idle but at a low RPM (about 500). I can tell it is idling low because the headlamps grow brighter when the accelerator is depressed. If I depress the accelerator and let off it will drop to almost stalling, bounce back up to about 800 RPM, then float up and down to almost stalling and level off at 500 RPM (too slow?). When it warms up it is not as bad but still has the problem. Anyone know what it could be? TPS, Bypass valve?, etc. HELP!!
Old 11-09-1999, 04:57 PM
Phillip Guidry
Phillip Guidry is offline
Phillip Guidry is starting off with a positive reputation.
start by SCRUBBING the throttle bores clean with solvent & a brush & a rag,while holding the plates wide open. Also disassemble the air bypass for a thourough cleaning(you may break the gasket!).These are 2 places that get sprayed often,but never SCRUBBED. It does make a difference.
Phillip
ps. Try some new plugs also
Old 11-13-1999, 09:23 PM
Tom1.0
Tom1.0 is offline
Tom1.0 is starting off with a positive reputation.
THANKS PHILLIP!!!
It worked! My Bronco is running like a champ now!
Old 11-15-1999, 10:19 AM
Phillip Guidry
Congrats ! You have gained experience that is invaluable.The scrubbing of the throttle bores works for every vehicle,even carberated ones.Try it on all your engines.
Phillip
bronco cam
10-21-2002 06:25 PM
honney
03-23-2002 01:22 PM
Bronco Billy
03-17-2002 10:09 PM
ricciardelli
10-03-2001 12:04 PM
PBOCfish
09-06-2000 06:19 PM
Quick Reply: 1990 5.0l Bronco idling problem
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
