'86 Bronco 2.9L V6 Engine R.P.M. faltering - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 11-16-1999, 06:43 AM
Larry
Larry is offline
Larry is starting off with a positive reputation.
I've got 2.9 V6 in my wifes Bronco & it'll sit there & idle smooth as silk then all of a sudden the revs will drop to about 400 & it'll run like ****house. This problem also occurs @ hiway speeds--any ideas on a cure ?? Thanks, guys !!
Old 11-16-1999, 07:17 PM
bob
bob is offline
bob is starting off with a positive reputation.
Old 11-17-1999, 10:12 PM
lonewolftom
lonewolftom is offline
lonewolftom is starting off with a positive reputation.
I had almost the same problem with my Bronco V8.
Remove the Air Bypass Valve and clean it out good.
Also use Carb cleaner to swab out the throttle bores and butterflys in the bore.
My truck runs like new since doing this.
Old 11-18-1999, 03:49 AM
Larry
Larry is offline
I cleaned the by-pass valve once, but maybe not enough, so I'll try it again--thanks for the suggestion !!
Larry
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
