Should "y" manifold have continouse vacume?
Hey Fellas, I own a 99 superduty 7.3. Lately I've had a series of problems. Ist problem I had was that the engine would shut off, I would let it sit for 20 min. then it would start and run for a 1/4 mi. Fuel pump and filter were replaced and continued. So we changed the cam sensor, the injector harness, 1 injector, the map sensor. After all those repairs have been made, truck runs fine until tranny shifts through all gears to overdrive and at 45 mph through 60 mph. the engine seems to spudder, if you put the pedal down, it runs good. I attempted to find leaks with soapy water, none were found. The only thing that I found was the the "Y" manifold does not have constant vacume........should it? As you can see we've done alot and almost there, if you guys can help it would be greatly appreciated!! Thanx Guys!!
on
I would suggest cleaning your ebp tubing that goes from your sensor to the front of the pass. side exhaust manifold.. I find it easlier to just remove it to clean.. Some guys run a weed eater .095 dia cord down the tube. Does not take that long to remove it, unless the fitting on the manifold is rusty.. If that does not fix it, you might consider replacing the sensor..
If you let completly off the pedal does it go away. And if you give it a little fuel it shudders the worst? If so you got another bad injector hideing in their. That sounds exactly what was wrong with mine i payed hell for over a month trying to find the little bugger too. If you can run a Change in Rotation Violicity test(you need a really good scan tool) and a CCT(Cylinder Contribution Test).
<TABLE><TBODY><TR><TD vAlign=top width="100%">If you let completly off the pedal does it go away. And if you give it a little fuel it shudders the worst? If so you got another bad injector hideing in their. That sounds exactly what was wrong with mine i payed hell for over a month trying to find the little bugger too. If you can run a Change in Rotation Violicity test(you need a really good scan tool) and a CCT(Cylinder Contribution Test).
</TD></TR></TBODY></TABLE>
Yes sir! that is exactly the problem,Thanx again guys! I'll try cleaning the lines first, but you are probably right another $200.00 injector. I sure hope one of these is the cure, if not I'll be sure to hound you guys again.
<TABLE><TBODY><TR><TD vAlign=top width="100%">I would suggest cleaning your ebp tubing that goes from your sensor to the front of the pass. side exhaust manifold.. I find it easlier to just remove it to clean.. Some guys run a weed eater .095 dia cord down the tube. Does not take that long to remove it, unless the fitting on the manifold is rusty.. If that does not fix it, you might consider replacing the sensor..
__________________
Which sensor is that boss?
__________________
on
__________________
Which sensor is that boss?[/QUOTE]
If you are looking for the ebp sensor, it is located behind and down from your belt idle pulley. (right next to the heater hose). Under the sensor you will find the tubing that goes to the pass. side from exhaust maniford. Carbon build up in the tube causes the sensor to malifunction.
Beechkid
Garage & Workshop
08-20-2017 01:53 AM
lothar 2112
11-05-2002 10:21 AM
