Transmission question again
Old May 24, 2007 | 07:24 AM
ppauto's Avatar
ppauto
Asked question about overdrive possibility for 1987 F150. Absolutely no response either way. Thanks guys. I won't bother you again.
Old May 24, 2007 | 11:33 AM
ryan f150 4x4's Avatar
ryan f150 4x4
Smile
We would be glad to help just need more info. moter size manual or auto trans thay both have overdrtive
Old May 24, 2007 | 11:29 PM
ppauto's Avatar
ppauto
It's a 302 with a C6 auto. The transmission is having problems. If I have to replace it, I would like to go with a 4 spd overdrive. I'm looking for information on what would be the easiest conversion. Surely someone has tried this before. Thanks
Old May 24, 2007 | 11:43 PM
ryan f150 4x4
you can put 4 speed o/d trans in your truck but you would need all the stuff to go with the trans wireing and linkage and comp.maybe drive shaft
Old May 24, 2007 | 11:53 PM
ppauto's Avatar
ppauto
Which transmission should I use?
