1989 F150 Brakes just went out
I was driving my '89 F150 yesterday when the brakes started getting worse and worse all of the sudden. I limped home but now I don't know where to look. The peddle goes to the floor. Very little pressure. How do I test my master cylinder? The pads in front are fairly new. 6 mo. or so.
I had the same thing happen to me. All of a sudden lost all braking power.
Turned out that's what happened:
1) The calipers went bad, the rubber part in them
2) Air got into the system
3) Air + brake fluid produced water
4) Water in the system corroded the master cylinder
5) The master cylinder failed to get enough pressure
The brakes would lock up, heat up and fail. Then after cooling off, work again, but temporarily.
I replaced both calipers and master cylinder and basically all of the parts in the system minus the brake lines.
If I had a 89 as a daily driver, I would replace these things pre-emptively.
