gas or electronic
Old May 20, 2007 | 09:48 AM
forever6es's Avatar
forever6es
gas or electronic
please help two weeks ago my six 87 f 150 efi started choaking out after warming up no rpm s would have to flutter gas peddle to get rpm s up like i had bad gas or something methyl hydrate no help then altenator caught fire (electrical plug common problem) put in new altenator but stillhave the same problem runs great cold but problem getting worse dont know if it s not getting fuel or not able to burn what it s getting fuel preasure at 55 psi
Old May 20, 2007 | 10:21 AM
Ranger GT2's Avatar
Ranger GT2
Is the check engine light on? Have you checked to see if there are any codes stored in the computer? Sounds like you are having a problem when the computer goes from open loop to closed loop. Could possibly be a O2 sensor, MAP, or wire connection.
Firefighter 1406
Mar 13, 2015 12:52 PM
USMCveteran
Oct 11, 2013 12:23 AM
abigaildevore
Sep 8, 2006 08:59 PM
cravenc
1997 - 2003 F150
Oct 28, 2005 03:57 PM
DGRIMM
1997 - 2003 F150
Mar 19, 2003 11:20 AM
