Six-Gun Towing a 7% grade --- Video link
10/4 on BTH. He has helped me on a few issues and although I don't know him personally, he always takes the time to help out if he can. I just recently asked him about the y-pipe fix. He was working on a few F-450's with this same problem, and said that it was the EGR Up-pipe that was slightly cracked. Im going to look at the 6.0 bible and see how I can inspect the the up-pipe...~Brad
Originally Posted by badbrad60
Pic of y-pipe to EGR
From the Passenger side exhaust manifold, the small branch the flares off the EGR cooler, is the assumed culprit. Not sure how to check other than rip it out and look.
Floyd, in regards to the heat issue and the tuner, as soon as I switched of the tuner, the truck shifted and allowed the engine to be out the "problem" zone of 2700 rpm..and be in the happy zone of 3300....But I hear ya...~Brad
Floyd, in regards to the heat issue and the tuner, as soon as I switched of the tuner, the truck shifted and allowed the engine to be out the "problem" zone of 2700 rpm..and be in the happy zone of 3300....But I hear ya...~Brad[/QUOTE]
Brad, my experiance is that these tiny cracks are often not visable untill she gets hot and things expand. If you take er off and there is no obvious crack try heating er with a torch. In the beginning I never noticed a problem till a burnt valve popped up. Burnt cause the freash air was coolin stuff down causing the valve not to seat properly. Back then there was no FTE, no puters........chuckle. In my jeepin days i soon learned to keep them motor mounts tight and to watch my EGT.
good wavey gravy my 05 made that same gawdawful noise. After several trips to the dealership , ( I actually switched from a car dealer to a truck dealer in between)
The tech replace the tensioner and the belt and the noise went away. I could watch my RPM drop when my truck would make that racket and the water temp would start climbing.
Mine would only do it towing my 44' trailer up a grade
Originally Posted by bfloyd4445
.... my experiance is that these tiny cracks are often not visable untill she gets hot and things expand. If you take er off and there is no obvious crack try heating er with a torch. .....
Try this. Something a little less obtrusive. Spray windex or cleaner on one side of the pipe and if you see wetness on the other side you have a crack.
I had a similar sound in my F250 while towing up 6-7% grades with my 12k Toyhauler a few weeks ago.
To me it sounded like a fan clutch as it was a more clearly skin crawling SCREACH for a few seconds when the cooling fan was engaged.
The reason I post is: Is it going to do me any good at all to take it to the dealership? The only time it happens is when towing up a steep grade with a full hauler... how am I supposed to replicate that for a tech?
Originally Posted by hotroddsl
dude I think yours sounds more like a belt slip issue than a exhaust leak
Similar to the sound my fan clutch made just before it went out on another one of my trucks...
I am going to mention the belt slippage issue to my dealer, they just recently had to replace the power steering pump...
Hey fellas, I have a stock 2005 PSD which I run with only top quality synthetic oils. My PSD still whistles when towing my 30ft 7500lb fiver uphill. I'm taking the whole outfit to my dealer for a ride along with a tech this Saturday. I was a trucker for 8 years and I know this whistle is not normal.
#30
When my truck did this pulling hills with the 5er weighing 12,000 lbs. I read a post where the op had replaced the tensioner on his fan belt. Well that was the exact same problem mine was. There was definately a difference. If you can move the tensioner with a standard ratchet and not straining then it is weak. A new tensioner takes a breaker bar and lots of pulling strength... It is a lot easier solution to try first. Just trying to give anouther solution that has worked. And mine was a mix of screech and whistle was hard to describe.
