1978 - 1996 Big Bronco
81 bronco 302 weird carb
Old 04-23-2000, 12:28 AM
talldave's Avatar
talldave
talldave is offline
i have an 81 bronco 302 with the weirdest carb i have ever seen.it is a variable venturi ? it starts easy enuf, but idles very high until driven for 10-20 minutes. the outside temp seems to affect it. then when the eng gets warmed up the idle drops lower than normal and eng quits. can i bolt up a normal carb to the existing manifold? will i get better mileage ? any help is really appreciated. i also have oil pressure questions but will get to that next time. thank u all...
Old 04-23-2000, 11:28 AM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
Talldave ,
Is your Carb the one with the sliding choke plates ? Ive seen those plates stick on those carbs . They are beasts to work on and get them to work properly . The plates need to be lubricated beacuse they will stick partially shut .
Paul
Old 04-23-2000, 12:29 PM
slikness's Avatar
slikness
slikness is offline
I've heard nothing but bad things about the variable venturi carbs. You should be able to bolt any aftermarket carb to your manifold. I would suggest the Edelbrock 600cfm with electric choke. It's about as trouble free as you can get.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old 10-10-2000, 11:27 AM
bgodkin's Avatar
bgodkin
bgodkin is offline
or consider a 600 Holley. I bought a edelbrock a couple years ago for a 1978 f-150 302 4 spd and had a bear of a time getting it tuned right. it also came with the worst bracket kit I have ever seen. I wound up just making my own throttle cable bracket. The holley also has parts available at most any auto parts store.
Old 10-11-2000, 02:15 AM
Superdave's Avatar
Superdave
Superdave is offline
I have not done it my self, but I have been told you can replace this carburetor easily with a regular Motorcraft 2150 2 bbl.
Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
Old 10-12-2000, 02:51 PM
AlM's Avatar
AlM
AlM is offline
rblount
04-12-2015 09:39 PM
c.l.nye
12-20-2010 09:58 AM
four-sixty-power
18
07-16-2005 10:50 PM
ricster737
25
03-01-2005 06:31 PM
bronco--351W
08-22-2003 10:15 AM
Quick Reply: 81 bronco 302 weird carb
