oops
Old May 13, 2007 | 09:55 PM
dirtynails's Avatar
dirtynails
oops
Two weeks ago I installed a new Bully Dog 6 Position chip on my '97 psd. She has 217000 miles and the only other mod is that the cat converter is out.
No problems for two weeks then all at once on friday am, all of the injectors on the right side quit. I was running the truck with the chip set on the stock setting at the time. Any ideas?
Old May 13, 2007 | 10:23 PM
10bands's Avatar
10bands
Probably the under valve cover wiring harness or maybe just the valve cover gasket. I know very litte about that stuff except that when the whole side quits it's probably wiring and those harness' going bad isn't uncommon. Others here will be able to give you more info.
Old May 13, 2007 | 11:08 PM
bigbadwolfe's Avatar
bigbadwolfe
could be the IDM that happened to me
Old May 14, 2007 | 09:12 AM
Neal 97 250's Avatar
Neal 97 250
I agree with 10bands. I would check there first and if it is fine there then I would go IDM.
Old May 14, 2007 | 09:27 AM
bkcowboss's Avatar
bkcowboss
I second the IDM, of course you want to check the cheap stuff first. There is a place that rebuilds idms in florida, i would check them out.
Old May 14, 2007 | 11:17 AM
Copedawg's Avatar
Copedawg
I found a IDM in a junkyard (cause I'm a cheepskate) out of a Ambulance $75 and still going strong. If you go that route before you buy it, SHAKE IT if it has water in it keep looking.
Old May 14, 2007 | 12:37 PM
Neal 97 250
I have been looking for the website of the place that does the IDM mod for you and rebuilds IDM's and I can't find it anywhere. Hopefully someone else will post it here for you.
Old May 14, 2007 | 02:33 PM
tjbeggs's Avatar
tjbeggs
Are these the guys you looking for?
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
I have heard good things about them.
I also concur that it more than likely the IDM that has gone out. 9 out of 10 times when a whole bank goes down thats what it is.
Old May 14, 2007 | 02:40 PM
Neal 97 250
This will definately work but I though I saw someone on the net that would do it for $100.00 plus shipping. Maybe I was dreaming. Thanx Tim
Old May 14, 2007 | 02:52 PM
tjbeggs's Avatar
tjbeggs
Oh, do the mod not just rebuild. Yeah I have seen that but can't find it right now.
Old May 14, 2007 | 04:19 PM
Copedawg's Avatar
Copedawg
What do they do to modify it? What does it do better? Faster? more power? chick magnet?
Old May 14, 2007 | 04:20 PM
powerstroked162's Avatar
powerstroked162
Got ya covered Timbob. Beans Diesel Performance will do the mod for 1hundo. They send you a modded IDM, either 120v or 140v and you send yours back to them after you install the new unit. Good luck.
Cowboy Steve
Old May 14, 2007 | 04:23 PM
powerstroked162
They supply more electrical power for the Injectors I believe. Rubberduck knows more about this then I do, Tim might even have some stashed info on the subject. Some have seen slight power gains, and others have noticed substantial power gains. I have heard anywhere from 20lb ft. to 70lb ft. Good luck
Cowboy Steve
Old May 14, 2007 | 04:30 PM
tjbeggs's Avatar
tjbeggs
here is a how to
http://www.forgotton.net/diesel/idmmod/index.htm
The IDM mod supplies more voltage to the injectors that results in faster and more precise control of the injector. I have not heard any numbers but a few guys claim a seat of the pants difference.
Old May 14, 2007 | 04:36 PM
powerstroked162
Somebody put it on the dyno and gave us some numbers, but for the life of me i cant remember who. I wanna say it was CudaJim
Cowboy Steve
