What engine will fit a '92 Lincoln Town Car
I believe the rearly 4.6L engines were unique. Only 92 may fit. I did a 94 Cougar and it had to be a 94 Cougar/T-bird engine. TC and CV engines would not work. I had a link that expained the difference thru the years, but it doesn't work anymore for some reason.
This was it. http://www.modularpower.com/engine.htm Perhaps their server is down.
A local salvage yard should has an interchange book and can tell you what will fit.
You need to know if it has an AOD or AODE, if it is an AOD only 1 year 4.6L'd will work as said above, if it is an AODE you can use just about any newer 4.6L with some electrical work. Check out crownvic.net, it is a great site for that platform.
For CV and GMQ's the build date they switched to AODE's was 1-17-92 IIRC. I assume the towncars were the same.
TS6034
09-29-2009 07:32 AM
dopedawg
06-11-2008 05:45 PM
aharrell
07-28-2003 08:39 AM
