Is there an ohm test for the EBPS
05-13-2007, 08:05 PM
on
Dont have an AE and just wanted to test the sensor.
05-13-2007, 08:11 PM
It reads voltage.
Pressure (psi) / Volts (DC)
0 / 0
8 / 0.25
20 / 1.45
50 / 4.45
53 / 4.75
60 / 5.00
05-13-2007, 10:12 PM
on
So is there a baseline range at idle for good vs bad
05-14-2007, 07:05 AM
Idle should be between 10-15psi and WOT under load should be around 40 - 50
Those are the only values listed in the manual so you have to estimate where your actual readings fall
05-14-2007, 11:10 AM
on
ok thanks. Im still chasing the low MPG. Ran a scanner and no codes so im just seeing if all the sensors are just a bit out enough.
