Home Video - F350 pulling Semi out of mud
#46
Semi's tend to get stuck easily since most just have open diffs on the axles. I've seen them in snow/ packed snow conditions spinning up gradual hills on the freeway when I was just in rwd not spinning at all.
#52
We used to run a Ford LN9000 single axle with a 30' pup. We would get her stuck, and a single axle has a lot more traction than a tandem, and with a litle "snap" from our f-150 RWD out she would go. Anyone who has ever worked around trucks understands how it doesn't take too much sometimes to help out. Stuck means you can't move under your own power and lot's of times a good tug is all you need. Of course there are times that a 966 has a hard time to break a truck out, but that's another story.
#53
Originally Posted by duffman77
...I dont care if his F350 has 5000Hp, a 10,000 lb truck can not develop the traction to move a 80,000 lb rig...
#54
Originally Posted by Big Orn
Wha.........!!!!!!!!! I gotta call BS on that one, steven!!!
#57
Originally Posted by johnnysF350
If anyone doesnt believe this one, then they need to go to You-Tube and find the video of the Super Duty pulling a semi up a snow and ice covered hill....
http://www.youtube.com/watch?v=ju-h_DiE9So
#58
Originally Posted by DonJames
The F-350 was not pulling the total 80,000# by its self, it was HELPING the rig. Like someone previously said, sometimes it only takes a couple thousand lbs of pull to help aide in vehicle recovery.
great video, wish it was during the day!
#59
I pushed a honda civic up a pretty steep once in the snow.WAIT before everyone attacks me and says "YOU CANT PUSH ~2500Lbs" Obviously not. its the same concept with the 80,000Lbs truck as bbender states above. simple concept
#60
Haha, I love it when the diesel guys show up. It's just a good thing the F-350 was a diesel or it probably would have gotten stuck itself because no gas motor could even come close to pulling a SD through the mud. Even in 4-LO, there is no way that a gasser could make it on anything but flat land with the wind from behind.
Ok guys, I think if you mention needing a diesel just a few thousand more times you might justify why you own one and pay 3 times more for oil changes and parts and about 50c more per gallon of fuel.
Meanwhile, us gasser guys will polish up our street queens.
Look at the beginning of the video, you can clearly see the driverside tires sunk down to the rims. There was probably a trackhoe behind the semi pushing it. Haha yeah...
What a joke.
What a joke.
