Stock trans temp gauge
All,
Today I noticed at cold start up my trans temp gauge was up about 1/4 way. After driving a mile or so it went into the normal range (half way) and stayed there. after sitting bout 6 hours went to start up again and gauge was at 1/2 way (normal).
Does this mean gauge is bad? Send unit (if it has one) bad? Any help is appreciated!
Thanks
JD
2002 f250 auto 7.3
Thanks
JD
2002 f250 auto 7.3
The in dash gauge is known around these parts to be just shy of useless. I really wouldn't pay any attention to it unless you are towing, and then only if tranny temp is something you're concerned with at that point (i.e. hot day, heavy load, hills, etc...) Another reason to buy gauges! PMS strikes us all at some point.
I'm in Alb NM, needle on gauge comes up to half way point when at normal op temp. Only had it rise near yellow during towing and steep grade. Pulled over and let cool down. Never seen it get stuck, strange thing tho when key is inserted and ignition is turned on needle drops all the way down from half way then moves back to half way point.
k2vailkid, curious about your turbo amplification mod. what is that??
JD
JD
The stock trans gauge just looks cool. Its function is to tell you the trans is not at 250*. At 230* is when you need to cool off. Its basically a dummy light. For real tempatures(at to better monitor your trans) buy an aftermarket gauge?(autometer,isspro,etc etc).
There was a topic just earlier this week about removing it and some people said to keep it, some said to ditch it. IDK what side I would take after reading that post.
Originally Posted by yamaguy
Yea I remember someone posting that the stock trans gauge really only has three positions, cold, normal, and oops,too late!
truckeemtnfords
03-04-2011 12:37 PM
