Can't get rear axle to slide out Help!
Maybe I'm a dope, but I pulled the diff cover off, pulled bolt for shaft out. Then slide shaft out and tried to push axle in. It won't go in. Slides in about the same amount as if the shaft was in there??? I can see it move slightly in and out but that is it. What am I doing wrong?
Originally Posted by 96onefifty
Did you remove the axle retainer clip? I've done it myself a time or two.
Thats the spring for your limited slip clutch pack. Well first off if you got the center pin out which i beleive you said you did. go ahead and pull the z shaped spring out. they are a pain to get back in unless you have the right tool. but after you pull it out slide the axle back in and the c clip should come right off. To get it back in I kinda Wegde one side of mine in and use a screwdriver to pry the other side in not the best but it worked let me know how you make out.
Originally Posted by philly5eagle
If you mean the c clip, I can't get to it. There is some sort of metal in the middle of everything that looks like a Z and seems to hold all of the gears in place. The axle won't move in far enough to get to the c clip
If the spring is in right you should still be able to push the axle in and get them off.
I put the spring (Z) in on the bench before I put the carrier in and I can still it the "C" ("U") in and out.
You may have to pull the spring part way out to get them off but if you pull the spring all the way out it is hard to get it back in.
the spider gears should stay in place. just dont spin the carrier without the pin in the center or the gears will fall out and while they arent hard to put in its a pain getting them lined up. but i would try to get the c clip out first without taking it out like subford said i just assumed you tried and couldnt is y i said to pull it out.
I had someone push on the axle and I was still able to move the c clip around without any resistance so I don't think that is getting stuck by the z spring thing. I even tried to smack it with a hammer and it only seemed to come in a fraction farther. It's as if the pin was still in there(it's not!) I even was able to push the other side in and get to that c clip easy. What could be stopping it??? Should I just keep smacking it with a hammer? I should have been done with this by now and I can't get the axle out.. l hope someone can help.
First remove the S spring which will give you a full view of what's going on.
Knock the S spring about half way out towards the front of the case.
Then rotate the carrier so the S spring can be grabbed with pliers and pulled out. The first photo in box #1 describes the procedure.
The second photo shows the parts inside the diff.
When you're ready to install the S spring, find a thin piece of sheet metal.
I used a piece of roof flashing. Place it against the ring gear so that when you tap the S spring back into position, it will slide down against the sheet metal. Then pull the sheet metal out.
Go Ravens
Go Ravens
I'll have a heck of a time trying to get the s spring out b/c currently it goes up over the end of the axle b/c I can't get it out. I tried banging on the end of the axle trying to push it in and it seems to move a "fraction" in. I don't know if I will be able to get the spring out b/c I tried to pry it out and no luck so far.It's hung up on the end of the axle.
It just doesn't see to be blocking anything. I have moved it side to side and up and down and no change. the odd thing is the other side slides like it should. I'm about to tow this thing away.
The only thing I remember is the S spring can only be pounded in a certain direction
to take it out. If you pound in the wrong direction, the S spring will just hit the axle shaft.
Take a good look at photo 1 for the S spring orientation for removal.
I got my axles out without taking the spring out. I just turned the tire while the axle was pushed invand the c clip should fall off. I may have used a screwdriver to push it off I don't remember. Pay attention though because the top and bottom gears will probably fall out and you will need to know how to put them back in.
