anyone heard of a dana/spicer 53?
I got a '50 F-1 that's had some work done (but still needs a lot more) and I was looking at the rear axle and the only thing I can find was a 53 in the spot where the model number would be. I've never heard of a dana/spicer 53. Anyone have any info on this? I've tried a few searches online but I've come-up empty.
Originally your rear axle would have had a metal ID tag on it with ratio and other info. 44's have a ten bolt cover. The ID tag was at roughly 8-9 o'clock on the cover.
Originally Posted by 51dueller
Some ***** trucks used a Spicer 53 rear axles.
48 - Early 51 used a Spicer 41
Late 51 - 56 used a Dana 44
Did a part number comparison between the two.
The 41 uses a different housing, cover gasket and ring and pinion.
Axle shafts, bearings, shims, washers, seals, companion flange are the same as a Spicer 44.
1948/56 Truck Parts Catalog. Rear axle parts lists: 59, 60, 65.
Here's the housing part numbers Bill if your curious:
Spicer 41 - 8C-4010-B
Dana 44 - 1C-4010-A
Dana 44 - 1C-4010-A
41 = 8M-4205-A
44 = 1M-4205-A
FYI: Studebaker cars and 1/2 pickups used 44's from 1940's thru 1966. In South Bend, Indiana, there a place that has NOS parts for these rear ends = SASCO. Need any Studie p/n's? I have the parts catalogs. Another place is Studebaker International, in Greenfield, Indiana.
RMPC
05-25-2021 01:22 AM
RMPC
32
04-29-2019 06:20 PM
Jolly Roger Joe
09-18-2016 11:07 AM
