Fuel pump replacement and turbo o-rings?
I took my truck by the stealership the other day because i sort of know the head deisel mechanic. For some reason it seems to dump fuel when i first turn it on, out the back of the motor. He said he thinks the fuel pump is on the way out, and that the slow oil leak i have is from the O rings on the up pipes of the turbo. So i am about to move, and i dont think he is going to have time to replace these things for me, and i am not sure ill have time untill Im in my new house. I was wondering how hard it is to replace the fuel pump yourself and the part number? Also does anyone know the part numbers for the O-rings so i can by them from powerstrokeshop.com? Also he mentioned i should replace all the shorter fuel lines running from filter to pump, and then pump to whereever. Are the part numbers for the short hoses, or do i just by a couple feet and cut to size? Anything special about the fuel hoses? I know i could do this, but I am short on time, and when i get to florida, I wont have any friends there to help me. Let me know what you guys think.
Thanks
Thanks
The are no o-rings on the up pipes. Maybe you mean the trubo pedistal o-rongs
Replacing the FP isn't too hard, just time consuming. If you have a california emmissions truck you need to remove the turbo anyway. Look here:
https://www.ford-trucks.com/forums/5...ight=fuel+pump
Read up on it and return here for your more specific questions
Here's the part #'s:
http://www.thedwilsons.com/powerstroke/PSD_Part_Numbers.html
Hi guys sorry I havee not posted on here for a while, but here I am again.
f4tz.9va543.aarm pump list $753.04 FTE $677.74
F4TZ.6K854.C gaskets list $ 10.77ea FTE $7.75ea
F4TZ.9324.AA fuel line list $ 7.11 FTE $ 3.84
F4TZ.9324.BA fuel line list $ 5.98 FTE $ 3.23
F4Tz.9324.CA fuel line list $ 7.20 FTE $ 3.89
F4TZ.9324.DA fuel line list $ 5.21 FTE $ 2.81
F5TZ.9G270.A fuel cap list $ 21.11 FTE $ 11.90
I hope this helps.
Willie
www.fordpartsguy.com
I hope this helps.
Willie
on
1 Post
Here are some part numbers for the fuel pump and banjo bolt seals
Fuel Pump
(International) 1824415-C93
(Ford) F6TZ-9350-A
(NAPA, Kragen/Parts America, AutoZone etc) 61067
Fuel Pump, Banjo Fitting
(International) 1821624-C92
Fuel Pump Banjo Gaskets
(Ford) F4TZ-9A375-A
(International) 1820650C1
If I remember right the last fuel pump I bought was $150 or so.
that is for the injector pump. If it is the other pump
F6TZ.9350.A LIST$ 149.00 FTE $116.22
WILLIE
WILLIE
yeah I goofed but thanks for catching me. Everyone needs a little nudge every know and then.
Willie
Willie
redmondjp
12-27-2022 09:43 AM
02 F250 7.3l
15
05-03-2015 09:59 PM
Coccyx
08-02-2010 12:53 PM
