Factory negative battery cable routing & terminating
While working on the engine a while ago, I found the negative battery cable was bolted onto the ignition coil bracket next to the steel fuel hose! The cable looks like it was a replacement; someone got lazy and terminated it wherever was handy.
I need to know the original negative cable's routing. What is its length and where does it originally terminate? As far as I remember, it originally was lower on the engine near the starter. Is this correct?
Thanks for the picture Dennis. As you know my truck is buried...
Your cable clamp does not look quite like mine tho. Mine is an actual electrical connection. The rubber-plastic part is just barely larger than the cable. Yours looks larger, like an insulated clamp. -hmmm???
A normal cable could be used, just carefully strip off the insulation in the tab area. Modify a copper pipe clamp (steel with copper plating) to wrap around the cable. Solder the clamp to the cable. Cover the cable section with liquid electrical tape compound. Bolt tab to cleaned and prepped frame.
polarisman729
09-18-2021 09:40 PM
Rick_Fury
05-03-2013 03:22 PM
52'F-3
09-22-2007 07:42 PM
BroncJMU
01-10-2005 03:00 PM
