1978 - 1996 Big Bronco
79 Bronco Trans Problem
Old Mar 20, 2001 | 03:41 PM
airran82's Avatar
airran82
My trans needs to be replaced. It's C6 on a 351m 4x4. What I need to know is, can I get a 4speed auto trans for a 79. If not
then I have another problem. When driving at highway speed(45-55)
the rpm's are at 3500 to 4200. Is that normal or is that the bad trans. Also in 4wheel drive the rpm's are lower than in 2wheel drive. In 2wheel she is screaming. Please help thanks.
Old Mar 20, 2001 | 05:45 PM
Bob_VT's Avatar
Bob_VT
You need a transmission that is for a big block 351M/400/460 to match the bell housing pattern. You might want to check to make sure you have not lost your linkage (bent, rotted, just loose) to the transfer.
Old Mar 20, 2001 | 08:18 PM
Torky's Avatar
Torky
I don't think there is a good 4-auto solution for you. The 460's went from C6 to E4OD. The E4OD is electronically shifted. The old AOD 4-Auto didn't need a computer to shift, but don't think it would take the torque without setup work, and the bolt pattern was 302/351W type.
Old Mar 25, 2001 | 10:11 AM
etobolski's Avatar
etobolski
You could put an E4OD in there. You will need to do something about the computer though to get the tranny to work right.
Old Mar 25, 2001 | 07:26 PM
mxer201's Avatar
mxer201
