problem with 429 coils blowing
Old May 4, 2007 | 08:30 PM
southern_il_ford's Avatar
southern_il_ford
Exclamation problem with 429 coils blowing
I had my truck running, when it just shut off. I figured it was the coil, so I replaced it and it worked again. The problem is I blew this coil too! i checked the coil with a tester light, and it gives off a very dim glow. I then tested the brainbox, and it gave a brighter glow. I have no clue what is going on. Can someone please help? MUDFEST IS IN A WEEK!
Old May 4, 2007 | 10:58 PM
darrin1999's Avatar
darrin1999
are you sure youre getting the right coil? if youre asking for the coil for the 429 then theyll give you a points coil because they were all points until they got re-released in the 80s in big trucks, if you ask for one for a mid-late 70s 460 then theyll give you one for electronic ignition
Old May 4, 2007 | 11:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
Make sure you have a ballast resistor in the ignition coil feed circuit.
Old May 6, 2007 | 10:07 PM
southern_il_ford
thanks, but i found the problem. one of my coil wires melted to the exhaust manifold, and it was shorting the coil out. thanks though
