Spraying coolant out degass bottle?
Thank you. that helps. I am not having Head gasket symptoms but the coolant from the degas bottle is annoying me, it does not run hot at all. I will look in that direction.
Also, bone stock. Not a single mod. I keep up on the oil, filter and fuel filter maint. I run Diesel Kleen and all in all I have had very few problems ( oil leaks aside ) with my truck.
With out knowing what ECT & EOT actually are or anything about your truck. I would be looking at oil & EGR coolers.
Pulling load = higher exhaust temp. + restricted coolant flow & oil temp rising in oil cooler = flash boil in EGR cooler.
You can't rule out head gasket.
A flush & coolant change & install filter might be all you need.
But you need to monitor (before & after) ECT & EOT to know if it helped.
Something to monitor engine is necessary to stay ahead of potential problems.
egregg57
01-08-2012 08:54 PM
