CCV mod
Old May 3, 2007 | 07:47 PM
powerstroked162's Avatar
powerstroked162
Thats a nifty Sleezbay kit Foreman. I think Im just gonna rig something up this next week. I might need pics Tim but Ii'll let ya know. Im pretty Sure Dusty could walk me through it via telephone. Thanks for the input boys1
Cowboy Steve
P.S.- Tim did you hear about my new idea I got brewin?
Old May 3, 2007 | 08:11 PM
tjbeggs's Avatar
tjbeggs
yeah twin huh. cool good luck with that!
Old May 3, 2007 | 08:15 PM
powerstroked162
Well that was yesterday. Today its gonna be supercharged turbo diesel time. I think I can make it happen yo.
Cowboy Steve
Old May 3, 2007 | 08:26 PM
tjbeggs's Avatar
tjbeggs
be prepared to spend 4 times more for half the boost! but more power to ya! By the way supercharged diesel are old school. many old two stroke detroits were supercharged turbo engine. a supercharger feed a turbo then into the engine
Old May 3, 2007 | 08:28 PM
powerstroked162
Wow, its raining on my parade over here in the E-burg all the sudden. Well I guess duals it is.
Cowboy Steve
Old May 3, 2007 | 08:34 PM
tjbeggs's Avatar
tjbeggs
compound turbos will be much easier and much more cost effective. plus not too many people have them so you will still be unique! better plan on head studs maybe even fire rings and rods. and depending on your boost level lower compression pistons!
Old May 3, 2007 | 08:41 PM
powerstroked162
Yeah, I figuered I'd go with Hypermax's headstuds, head gaskets and connecting rods. I'll throw their hot cam in as well while i im in there. The rings and pistons I was gonna have BDP do. *****ty thing is that im gonna have to pull the motor but im gonna do new uppies while im in there as well as the HPOP. long list but thats the best time to do it. Im starting my collection of parts. Where can i get an HTB4 turbinator? What motor does that come on?
Cowboy Steve
Old May 3, 2007 | 08:44 PM
tjbeggs's Avatar
tjbeggs
sounds like fun. I don't have any idea what engine that turbo comes on. call a turbo shop.
Old May 3, 2007 | 08:45 PM
powerstroked162
Stumped.......... Are you feeling ok? Better check your EGTs brother. lol
Cowboy Steve
Old May 3, 2007 | 09:15 PM
tjbeggs's Avatar
tjbeggs
I know a little about lots and I know alot about powerstrokes but I don't know every thing about anything!
Old May 3, 2007 | 09:55 PM
powerstroked162
Lol, how long did it take you to come up with that little saying? Maybe going into my sig.....
Cowboy Steve
Old May 4, 2007 | 06:29 AM
tjbeggs's Avatar
tjbeggs
only but a few seconds! It was a moment of inspiration!
Old May 4, 2007 | 06:45 AM
  #28
Cuda_jim's Avatar
Cuda_jim
Check this CCV mod. Scroll down the page for my picts.
https://www.ford-trucks.com/forums/5...ccv-flack.html
BTW: I use heater hose an place the mod into header collectors (gassers). Never had the hose melt, even with 800 HP (heat) pouring through them.
If weld the CCV into the exhaust correctly you may see an increase in HP, I've seen as much as 20HP by doing this mod. (Gasser not diesel)
Old May 4, 2007 | 02:08 PM
  #29
skittlejr's Avatar
skittlejr
is there any issue of exhaust pressure being higher than the crankcase pressure and back feeding fumes up the hose? just a thought, i dont know
we have been dealing with crank case breather issues on the CAT engines for the last few years and the new 07 stuff is probably going to need attention. if you go two turbos, steve, you might end up with the same issues-raising crankcase pressures by boost getting though shaft seals and on through turbo oil drains, causing oil carryover into the breathers. that's what happened on the CAT engines when they went two turbos. i would just run the hose far enough back to clear the cab. it would drip a bit of oil but my engine does that anyway, but i like the idea of dumping it in the exhaust. the epa would like that too IF any of us actually still had cat cons haha.
Old May 4, 2007 | 03:24 PM
  #30
tjbeggs's Avatar
tjbeggs
if you install the pipe in the exhaust with the opening facing the tail pipe you can create a venturi effect for the fumes. that way no pressure would be going the wrong way
