Bad vibration?
Old May 2, 2007 | 04:39 PM
fordmanjoe76's Avatar
fordmanjoe76
Bad vibration?
I have a '99 F-250 SD, 4x4, when I am on the interstate running 65 and up, going into any turn(even slight) causes a bad vibration in the rear. If I am driving at highway speeds, 65 and slower, nothing. Put on new rear shocks and it helped nothing. Anyone know what this could be? Thanks
Old May 3, 2007 | 01:05 PM
Blurry94's Avatar
Blurry94
Bump.
Old May 5, 2007 | 12:50 PM
fordmanjoe76
Bump? trying to be funny?
Old May 5, 2007 | 04:11 PM
rclarke's Avatar
rclarke
My first thought is if it has a locker rearend the clutches are sticking. A bottle of modifier might fix it. I have seen rearends that made a bang sound like a gunshot when going off onto an offramp from the freeway but a vibration could also result.
Old May 5, 2007 | 05:50 PM
Cuda_jim's Avatar
Cuda_jim
Bump, means taking your post to the top of the page, he's not trying to be funny.
Do you have a 2 piece drive shaft? If so, check the center bearing for loosness. It may need to have the spines re-lubed.
Old May 5, 2007 | 06:36 PM
fordmanjoe76
how do u re-lube the spines? Is it something that I could do myseif or do I have to take it to the stealership? Thanks for the info
Old May 5, 2007 | 07:51 PM
kotzy's Avatar
kotzy
The only thing a turn does is make the differential gears work, however at 65 your not going to make them work that hard since turns are really gradual. You are changing the load and thrust on wheel bearings that might be where I would have a look, get it on a lift or jack stands and see what they turn like by hand, then unloaded under engine power.
ncuffin
1997 - 2003 F150
Mar 2, 2024 10:19 PM
CPaulsen
Feb 13, 2015 09:47 AM
jake47
1978 - 1996 Big Bronco
Nov 21, 2007 02:11 PM
brandon0011
Sep 24, 2006 03:31 PM
