Dyno Numbers
Old May 2, 2007 | 08:05 AM
54-4U2C's Avatar
54-4U2C
Dyno Numbers
I got a call from Keith Craft Motorsports today that my engine is finished and the dyno numbers are in. They came out at,
HP 567
Torque 575
The engine is a 428 block FE with a 4.250 stroke and a 4.160 bore (461 displacement).
General info:
- Base Engine 428 Block Fully Machined, Scat or Eagle H-Beam Rods, Scat Cast Steel Crankshaft, Diamond Pistons, Plasma Moly Rings, Clevite or Federal Mogul Bearings, Melling Oil Pump, Ford Racing Oil Pump Drive, Stock Front Cover, Remote Oil Filter Mount , Fel Pro or Corteco Gaskets, Stainless Arp Accessory 12pt. Kit, BHJ Damper, Balanced & Blue Printed
- Camshaft Comp Cams Hydraulic Roller
- Cylinder Heads Edelbrock Stage II (CNC work done in-house)
- Valve Train T&D Rocker System, Comp Cams Pushrods and Crane Hydraulic Roller Lifters
- Injection System Very Cool Parts Stack Injection
- Computer F.A.S.T. System w/ Harness
- Oil Pan Canton T-Style w/ Pickup
- Valve Covers Finned Pent Roof FE
- Ignition MSD Distributor, MSD Plug Wires, NGK Plugs
- Water Pump Edelbrock Polished Aluminum
<O class=inlineimg title='\\"Stick' alt='\\"\\"' border='\\"0\\"' src="http://images.ford-trucks.com/forums/images/smilies/tongue.gif" <img Out Tongue\? />I'm pretty happy with the numbers and am one step closer to having the truck I've always wanted.</O class=inlineimg title='\\"Stick' alt='\\"\\"' border='\\"0\\"' src="http://images.ford-trucks.com/forums/images/smilies/tongue.gif" <img Out Tongue\? />
<O class=inlineimg title='\\"Stick' alt='\\"\\"' border='\\"0\\"' src="http://images.ford-trucks.com/forums/images/smilies/tongue.gif" <img Out Tongue\? /></O class=inlineimg title='\\"Stick' alt='\\"\\"' border='\\"0\\"' src="http://images.ford-trucks.com/forums/images/smilies/tongue.gif" <img Out Tongue\? />
<O class=inlineimg title='\\"Stick' alt='\\"\\"' border='\\"0\\"' src="http://images.ford-trucks.com/forums/images/smilies/tongue.gif" <img Out Tongue\? />I think these numbers sound about right for a 1954 F-100. Don't you?</O class=inlineimg title='\\"Stick' alt='\\"\\"' border='\\"0\\"' src="http://images.ford-trucks.com/forums/images/smilies/tongue.gif" <img Out Tongue\? />
<O class=inlineimg title='\\"Stick' alt='\\"\\"' border='\\"0\\"' src="http://images.ford-trucks.com/forums/images/smilies/tongue.gif" <img Out Tongue\? />Ron</O class=inlineimg title='\\"Stick' alt='\\"\\"' border='\\"0\\"' src="http://images.ford-trucks.com/forums/images/smilies/tongue.gif" <img Out Tongue\? />
ps. I posted this originally over on the 48 to 60 side, but was so happy that I thought I would share it here too.
Old May 2, 2007 | 03:04 PM
390fe's Avatar
390fe
That sounds sweet! I assume it runs on pump gas?
Old May 3, 2007 | 02:41 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Post photos on your progress, sounds like a great project.
Old May 3, 2007 | 04:41 AM
428HIGHBOY's Avatar
428HIGHBOY
That will be a blast to drive. Congrats!!
Old May 3, 2007 | 06:40 AM
54-4U2C's Avatar
54-4U2C
390fe,
Yup, pump gas. With the fuel injection it should be real reliable. I should be able to post pictures in a week or so, I'm traveling over the next few days for a niece's graduation.
Thanks.
Ron
Old May 3, 2007 | 07:04 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Ron Congrats man on the build,,KC does some bitchin work ...those head you have are going on my build... I love the old fat fender ford trucks..I have always wanted one.. That thing is gonna be kick A$$....
I'am also running a Hyd. Cam.. was a custom grind by Erson.. and it should really help those heads flow..
Cant wait for more deatils and pics...
RJ
