code P2285
Old May 2, 2007 | 06:40 AM
swunderle's Avatar
swunderle
code P2285
hey guys. my truck has failed to start a few times on the first key turn, then when it fires on the second try it sets the check engine light. The code that is set is a P2285 injector control pressure sensor circuit low. any ideas what to look at first? Is that low fuel or oil pressure? My truck has been trouble free except for a bad injector at 2500 miles, it now has 55000. any guidence would be great.
Old May 2, 2007 | 06:59 AM
BowTieHatr's Avatar
BowTieHatr
is your icp sensor in the head or under the turbo?
Old May 2, 2007 | 07:32 AM
swunderle's Avatar
swunderle
not sure my truck is any early 2003 if that helps.. What does it look like.
Old May 2, 2007 | 11:13 AM
BowTieHatr's Avatar
BowTieHatr
yeah its under the turbo. take it to a dealer.
Old May 2, 2007 | 11:42 AM
swunderle's Avatar
swunderle
thanks for the info
Old May 3, 2007 | 07:13 AM
BowTieHatr's Avatar
BowTieHatr
your welcome. anytime
Old Aug 24, 2007 | 12:01 PM
Willie1492's Avatar
Willie1492
P2285 and Engine Surges
I have the same problem. I've been getting a P2285 code. I have also noticed that my engine surges, mostly when it is still cold. It has stalled a couple of times at idle as well but it always starts right back up.
Looking at the freeze data for the code it always says that the engine is not running (0 RPM) when the fault occurs. Don't understand that.
I've read about the problems with the ICP sensor. I also read it costs around $750 to have dealer replace it.
Any cheaper suggestions before I break the bank and take it in?
Old Aug 24, 2007 | 02:01 PM
Ford Yankee's Avatar
Ford Yankee
My truck('04) has the same code,but runs fine (88,000 miles).... I bought this truck at 82,000 miles a month ago.
Took it back to the dealer to check and they are going to replace the ICP sensor, #1 injector and egr valve....Find a good dealer that knows the engine and have them check it out!
(I did a complete road test with the tech)
Old Aug 24, 2007 | 02:59 PM
BowTieHatr's Avatar
BowTieHatr
the part itself should be the highest part of the bill. labor to replace the sensor should be no more than 1.5 hours.
Old Aug 24, 2007 | 05:25 PM
Willie1492's Avatar
Willie1492
I'm takin' it in
Thanks for your responses. You guys have encouraged me and I'm taking it in on Monday.
I've got my fingers crossed. The five year, 100,000 mile engine warranty says it covers "Injector Pressure Sensor" It's $100 deductable but that's better than full price. It's a 2004 with 75,000 on it so we see what they say.
chiefn10
May 27, 2012 02:58 AM
rocky1074
Jul 15, 2011 06:24 PM
Qwatali Hunter
Mar 11, 2011 05:19 PM
AndeyHall
Jun 25, 2010 07:57 PM
sethjamto
Sep 14, 2007 07:45 PM
