Best way to clean axle tubes?
I seen the Ford mechanic use a power sprayer with solvent. I used a sock and an axle the last time I did it.
Make sure you spend some time on it, especially if you blew your diff. The little chunks like to hold up in the tubes and then come out and get your new gears and bearings....
(ask me how I know this.....)
I guess i'll make sure there 100% clean then. I originally was just pushing a rag through with a coat hanger and it didn't seem to be working very well. I finally hooked the end of the coat hanger and hooked the rag to it and pulled it back and forth several times and that seemed to work fairly well. I'll be sure and hit them up again. Thanks.
-Destin
-Destin
billcollector
04-17-2021 08:58 PM
LARIAT 85
04-30-2010 11:37 AM
