AUX bottom on my radio?
Yes it should work providing you do what the other guys said. You need to by a PIE adapter (ebay is a good source I have bought 2 from there with no problems). You plug the one harness for the PIE adap. in rear of radio after you remove, the the other harness you will need to find power and ground. Plug your IPOD patch cord into module and Wella. 1 hr. labor tops. ez install
alright i give up. i have searched the internet. i have talked to PIE and got many different answers. finally someone told me they didnt make those for my radio. i called vendors for peripheral but to no avail. does anyone know a good salesman somewhere that can help me?
here's what i got
2006 ford econoline
stock radio with single disc player. aux button. no sat button and no navigation or rear radio control.
here's what i got
2006 ford econoline
Look at this PIE adaptor. Add the item for the ipod (scroll down the page) and you've got what you want!
http://www.discountcarstereo.com/detail.aspx?ID=813
Peripheral makes an ipod adapter that works with the ford radios...The radio Must* have an aux button and be able to display MP3 text..This adapter is plug and play and does not require running a 12v and a ground...Also, you can control the ipod through the radio...Bestbuy sells this adapter and will install for about 50 bucks...
cecoen
1997-2006 Expedition & Navigator
10-20-2015 09:53 AM
northdakota 67ford
10-13-2014 02:35 AM
