1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2000 Exursion window problems
Old 03-02-2016, 08:54 PM
IHdieselfan's Avatar
IHdieselfan
IHdieselfan is offline
My Wifes Excursion's drivers window suddenly quit in the up position. I replaced window motor, no change.(note motor had been slow for awhile) so then I went to digging. both positions of the switch wont work auto or manual. So I used power probe to power motor to manually work the motor. Motor worked fine and faster now. I rolled the window down with the power probe again then plugged the connector back up and tried the switch. the window went up about 1" and quit, when it quit I heard a click behind the fuse box under the steering wheel, noticed that now none of the windows will do anything and lighting behind window buttons went out. waited maybe 15 seconds. heard another click then the lights came back tried all other windows except driver, all worked until I try the driver. went to the fuse box under the hood maybe the circuit breaker is bad. Removed it installed 30 amp maxi fuse. tried every thing again. no change. so I back probed the connector at the window motor with my multimeter. tried up the meter shows the voltage for just a second then goes back to nothing. tried down the meter blibs like it saw voltage for just a second but not long enough to actually show it. unplugged connector at motor and put leads directly to connector so there would be no load. same results. hooked up my snap-on scan tool and went into GEM. it shows the switchs working properly but never shows any amperage in the data display. also lastly I tried all three other windows up at the same time and it tripped that clicking sound again, waited a minute the they all went up fine individually. im thinking something in GEM but now I fine that the GEM is obsolete at ford place. (I'm getting bout tired of hearing that from them) Thanks for appreciating the stuff that sells the crap you make now.
IHdieselfan
09-21-2018 11:20 AM
teamlx88
1997-2006 Expedition & Navigator
02-02-2014 03:34 PM
bumblebee902
05-29-2010 11:26 AM
andyman91
03-13-2010 05:01 AM
ron's power stroke
06-28-2008 09:53 PM
Quick Reply: 2000 Exursion window problems
