Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
360 problom solved?
Old Apr 23, 2007 | 10:56 AM
mercury man's Avatar
mercury man
Lightbulb 360 problom solved?
The 360 that is in my truck right now is about to get removed in the next week or two. The guy i bought it from said it liked to over heat, but didn't know what was wrong with it. He put in a new water pump, rad, A few thermostats and a new rad cap. however, He didn't look at the intake bolts. upon closer inspection i found that there was no intake bolt on the passenger side at the rear and the intake bolt on the driver side rear was too long. I think this problom is solved what do you guys think?
Old Apr 23, 2007 | 12:03 PM
Fomoko1's Avatar
Fomoko1
Hard to say if the missing and incorrect bolts are the cause of the over heating, be sure to check the rad inside from the rad cap to see if it`s not corroded or dirty. Also the the fan belt is not loose.
Old Apr 23, 2007 | 03:22 PM
mercury man
The rad is fine, no corrosion and no bent fins. the fan belt was tight before i took them off for engine removal.
Old Apr 23, 2007 | 03:43 PM
loudfords's Avatar
loudfords
Don't remember how a 360 is, but on some engines you can get the LH & RH gaskets reversed and block coolant flow between block and heads, or heads and intake.
Old Apr 23, 2007 | 10:31 PM
Fomoko1's Avatar
Fomoko1
Good point, I`m fairly sure the 360 head gaskets can be put on the wrong so if someone has had the engine apart it would be good to check to see the gaskets are on rite to be sure.
We could use some more clues in order to help, such as how fast/badly does it over heat and any other info that you are aware of.
Old Apr 23, 2007 | 10:43 PM
66gpw's Avatar
66gpw
I had a rad problem in my 85 when I first got it. The bottom half of the rad was so full of stop leak that it plugged half the cores and made the coolant flow retstricted. Had to remove the rad and flush it out. No rad leaks afterwards. The stop leak was put in I suspect because some frost plugs were corroded and leaking.
So maybe the rad could be a problem.
Intake gaskets in backwards is also a good point. The bolts also can cause some over heating, but you would of notice coolant leaking here and white steam.
Plugged coolant routes in the block can cause problems.
I had a cxar that overheated and I ended up putting in an engine flush and ran the car for a awhile and man the car use to make all sorts of noises as the flush broke through plugged areas. Afterwards it did not overheat.
Old Apr 23, 2007 | 11:32 PM
preppypyro's Avatar
preppypyro
Hey mercury man, did you buy the brown one that that one fella had on here for sale awhile back?
Old Apr 23, 2007 | 11:34 PM
Snowking's Avatar
Snowking
Is that 61 Canuck's brown 1969, you're thinking of? Which if that is the truck you are thinking of, I think 61Canuck still has it for sale.
Old Apr 23, 2007 | 11:35 PM
preppypyro's Avatar
preppypyro
No I remember a fella having a mid 70's brown truck for sale on here... the guy was from stoon, truck looked pretty decent too.
Old Apr 24, 2007 | 10:08 AM
mercury man
I bought a 74' in the city, it has a darker red primer on it. it is the truck i got in my gallery.
Old Apr 24, 2007 | 11:06 AM
preppypyro's Avatar
preppypyro
That would be the one! Mind if I ask what price you got it for? When i talked to the guy he was readdy to sell it for very cheap.
Old Apr 24, 2007 | 11:09 AM
mercury man
I got it for $300. it is a good deal because there are many new parts on it including springs, shocks, brakes etc.
Old Apr 24, 2007 | 11:13 AM
preppypyro's Avatar
preppypyro
Oh yeah, although you might go to jail for stealing it from the guy!!
Great buy!
Old Apr 24, 2007 | 03:04 PM
Fomoko1's Avatar
Fomoko1
IT looks ok, straight and fairly rust free. I hope you find the problem real soon and it`s a cheap fix.
Old Apr 24, 2007 | 03:26 PM
preppypyro's Avatar
preppypyro
If you cant find the problem, you can always drop a 390 in er too
