turn signal problem
Old Apr 21, 2007 | 02:10 PM
dogobat's Avatar
dogobat
turn signal problem
my right turn signal quit; brake and markers, left lights work, only left when hazards are on - any ideas?
86 F350 diesel plain jane flatbed duals
Old Apr 21, 2007 | 02:51 PM
toms86ford's Avatar
toms86ford
sounds like it might be in your steering column if everything is working except your right turn signals or right side 4-way flashers....maybe even check for a good ground on the right side inside the the light housings.
Old Apr 21, 2007 | 03:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Some of these parklamp/taillamp sockets are plastic and replaceable. Do either bulbs on the affected side light up? A burned out bulb at the rear, will cause the front bulb to light up, but not flash. There are two flashers behind the dash...one for t/signals, one for the emergency flashers.
Old Apr 21, 2007 | 04:35 PM
dogobat's Avatar
dogobat
pretty sure its the turn signal switch taking a dump; now weird things happen when trying signals;
Old Apr 22, 2007 | 01:16 AM
dogobat's Avatar
dogobat
yup - turn signal was junk; good blinkyblinky and flashyflashy
Freightrain
Mar 6, 2014 09:29 AM
Duke78
Jan 17, 2010 04:58 AM
afonda
22
Dec 20, 2008 01:47 PM
cliebold
Jul 24, 2002 04:25 PM
