Strange sound
Old Apr 19, 2007 | 05:44 PM
Olddog66's Avatar
Olddog66
Strange sound
I’m trying to find the source of this noise that won’t stop. On 3 out of 7 stops I’ll hear this dull thump toward the front of the truck. It sounds like someone throwing a rock at a piece of foam insulation. It’s a low frequency thump or pop. I can’t tell but it seems like I feel it in my brake but that’s not for sure. Any suggestions?
Old Apr 19, 2007 | 05:49 PM
Benny2002's Avatar
Benny2002
Are you running your air conditioner alot? Mine makes that kind of a noise when the damper opens and closes on my AC system.
Old Apr 19, 2007 | 06:05 PM
Olddog66's Avatar
Olddog66
Ac
The AC has not been on yet this year I don't think that's it.
Old Apr 19, 2007 | 06:41 PM
Kwikkordead's Avatar
Kwikkordead
Remember that the AC runs if you are on defrost, or when the dial is set for vent and floor. It only DOESN'T run on the vent and floor only settings. AC is commanded on for every other setting.
Kind of a bone-headed idea IMO. They need a separate button to command the AC on and off like the VW's have.
Old Apr 19, 2007 | 09:05 PM
cangim's Avatar
cangim
Very common sound when the front ball joints are going out. you might jack the font up and see if you can move the joint around. I wasn't able to, but when I put a small floor jack under the joint, I was able to move it almost 1/2 inch. It occurred just as you described, when stopping but not everytime.
Old Apr 20, 2007 | 07:49 PM
Olddog66's Avatar
Olddog66
Yep
Well I think you are correct. Time to start thinking about how to do this job myself.
Thanks
Grinder Man
Oct 10, 2014 09:35 AM
BigGreen7.3swap
13
Sep 28, 2014 09:21 PM
cbr600rx7
47
Jan 30, 2013 05:48 PM
vr4mike
Sep 3, 2011 01:31 AM
