Modular V10 (6.8l)
Heavy Duty
Old Apr 17, 2007 | 09:47 PM
rob17's Avatar
rob17
Heavy Duty
This will sound like a silly question but what makes the V10 a heavy duty modular engine? I've ready things on this forum like "cross bolted mains". I'm not sure what that means but it sounds heavy duty.
Thanks,
Rob
Old Apr 17, 2007 | 10:02 PM
cds's Avatar
cds
Maybe because you can only get it in superdutys or motorhomes? Just a guess.
Old Apr 18, 2007 | 09:28 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
All modular motors, the 4.6L, and 5.4L and the 6.8L V10 have cross-bolted mains.
The V10 has SIX bolts on each main cap, two cross bolts (from the side of the block), and FOUR holding the cap down. I'm pretty sure the 4.6L have only two cross bolts, and TWO holding the cap down. I believe the 5.4L is the same as the 4.6L.
The V10 has a forged steel crankshaft.
Everything else, I believe is the same as the rest of the modulars.
Given 4.6L's and 5.4L's go 200K miles, and the V10 definitely goes that and further, personally I consider the entire modular engine line "heavy-duty".
But the V10 does have certain features that make it slightly heavier duty, as I said above.
Also, the under-hood sticker on my Superduty says "This engine conforms to ULEV emissions for Heavy-Duty Truck engines".
Which means, emissions-wise, it conforms to heavy-duty truck engine specs - which are more lax than passenger-car emissions specs.
So, there's two ways of looking at it.
It's called a "heavy-duty truck engine" for emissions purposes.
AND, it does have "heavy-duty" features in the block and crankshaft.
Old Apr 18, 2007 | 01:54 PM
Carpainter29's Avatar
Carpainter29
I just worked on a 2000 F350 XL, had the V10, with 320,000 miles on it. I was absolutely shocked, original.....
Old Apr 18, 2007 | 02:28 PM
krewat's Avatar
krewat
Find out what kind of oil he's been using!
I'd laugh my butt off if the answer was "whatever they had".
Old Apr 19, 2007 | 01:04 PM
Carpainter29
I talked to him bout it today when he picked it up. Uses regular PENNZOIL of all things with pennzoil filters, at 6000 mile intervals. Said it has been the best truck he ever had......basicially i am speechless. So mine using MC oil and filters at 4000 intervals should last me forever.............
Old Apr 19, 2007 | 07:31 PM
DirtyDogOfTheDesert's Avatar
DirtyDogOfTheDesert
My 3V 4.6 has 4 bolts on the caps plus the 2 cross bolts. I believe the 5.4 are also the same.
rob17
6.7L Power Stroke Diesel
Jan 29, 2015 01:21 PM
bingbing
37
Sep 30, 2011 08:18 AM
masterguns2003
Offroad & 4x4
Jan 25, 2008 07:04 PM
M1platoon
May 24, 2007 04:56 PM
Chris in SW Va.
Sep 11, 2004 04:36 PM
