to put in a feul pump?..it leaks..and i tightened all the loose clamps and big nut..
book says i have to remove the turbo...looks like it will come out to me with taking it out..
'thx in advance
turbo does not have to be removed,it just makes it easier to start the big fuel line nut.you can do it without removing turbo.just have to be careful when pulling fuel pump out not to drop the pushrod in engine.
'thx in advance
Use this link as a guide and you should be ok. https://www.ford-trucks.com/forums/5...ight=fuel+pump .
Now the only thing I change, is I use a 1 1/4" socket to get the banjo bolt off and not the wrench. I also used a universal to spin the socket and banjo bolt (cuz there is fuel that gets on it and it is slick/hard to spin) after I broke it loose. The socket I used is a craftsman 1 1/4" with a 1/2" drive. Made getting into that tight spot easier. Good luck and let us know if you need any more help.
