Locating fuel return line to tank
on
the return line will be the one up by the fuel filter that is coming off the drivers side of the housing and will have a short piece for hose connecting it to the filter housing. you will have to trace it back. it the smaller of the two fuel lines. it then goes to the tank selctor vavle then to which every tank your running on. I beleive the supply line is 3/8 and return is 5/16
