1978 - 1996 Big Bronco
weather striping
Old Nov 23, 2001 | 02:39 PM
sabre737's Avatar
sabre737
weather striping
Never done this before so I'm just wondering. How hard is it to remove and install weather striping on the windows and the tailgate?
Thanks Dave
Old Nov 23, 2001 | 05:19 PM
Bob_VT's Avatar
Bob_VT
weather striping
Hey its not too hard to do. Just don't rush the job. I am assuming you are only speaking of the weather strips for the doors and the back window right? The door strips go deep into the door in the channel and you may have to remove the window mechanism from the door to install it. If you are going to install the window swipe along the dottom window edge I recommend that you do remove the window track assembly. For the striping around the outside of the door use a drop of "GOOP" glue about every 6 inches to assist with the hold.
As for the back window the weatherstrip in the top just pulls out with a tug. It is just tucked in there under a slight lip. The rear window swipe can be removed and replaced with the window slig down butit can be tricky. This is held in by little sping clips and if you look at the new one you will understand how it attaches.
Good luck.
Bob
Old Nov 23, 2001 | 08:56 PM
sabre737's Avatar
sabre737
weather striping
actually i was refering to the weatehr stripping that seals the window, and keeps water from going down into the door and tailgate. Sorry if i got ya confused.
Dave
Old Nov 30, 2001 | 01:38 AM
Riso79's Avatar
Riso79
weather striping
Water will alwats go into the rear tailgate. Just like the doors, there are made to channel water through. Now if the stripping is cracked then that is adifferent story, those things can be sharp when they get old and brittle.
Old Nov 30, 2001 | 11:42 AM
Mil1ion's Avatar
Mil1ion
weather striping
EvinrudeDude300
Electrical Systems/Wiring
Feb 17, 2012 06:40 PM
FordManMT
Mar 27, 2011 04:59 AM
dave74-360bb
General Automotive Discussion
Sep 14, 2005 02:04 PM
countryboy29
Aug 8, 2002 08:23 AM
