Tips/tricks for braided hose
been a long time, had all russel on one of my lopars. I think you put the outer nut on the hose then rap the hose real tight with electrical tape, about 1.5 inch area, then cut it in the middle of the wraped area with a hack saw with a fine blade, then lube the center fitting and shove it in the hose until you can thread the outer nut on and tighten it up, snug but not to tight. Make sure your wrenches are clean and fit the nuts well, even if you have to use adj. wrench so not to mar. up the fittings.
When maiking up hoses, after cutting, I like to place the hose and fitting next to each other, marking on the hose how far inside the fitting the hose should travel.
Once you start assembling the hose and fitting, it's a visual reference to make sure you haven't pushed any hose out while tightening the assembly.
I also use Aeroquip fittings almost exclusively because their fittings swivel. It relieves the anxiety of having to index the hose fittings correctly when using angled fitting.
To stabilize the hoses after installation, I use Adell clamps.
http://www.boatownerswarehouse.com/b...fm/2,4921.html
Finally, if the steel braided hoses are gonna see a harsh environment where fine grit can penetrate the steel braid, you might consider using clear heat shrink to seal the outer shell of the hose. I have seen grit act as sand paper when it gets between the steel braide and inner hose.
