Sponsored by: Real Truck
04 leveling question, help
Old Apr 15, 2007 | 12:15 PM
locked up's Avatar
locked up
I saw some good reports on the donahoe mini packs leveling kit. I purched one and went to install it . My front springs do not have a center bolt. There is no way to install it as far as I can see. It says its for a 2004 F 250. Any ideas or suggestions??? My truck is a crew cab, 6.0 and all stock.
Old Apr 15, 2007 | 12:22 PM
75F350's Avatar
75F350
All leaf springs must have a center aligning pin. Without it the springs would seperate. The center alignment bolt is the only thing that holds the springs together. This bolt also centers the spring on the spring perch.
Old Apr 15, 2007 | 01:35 PM
locked up's Avatar
locked up
Where the u bolts pull down the block on top of the 2 springs it is solid.
here is a pic..wouldn't this be where the center pin would come through?
http://img239.imageshack.us/img239/8154/truck002va6.jpg
This is the top of the spring...u bolts..The mini pack has a long bolt that doesn't look like it would fit...Any help appreciated..I am not a great mechanic
Thanks
Old Apr 15, 2007 | 02:10 PM
Turbo_Whistler's Avatar
Turbo_Whistler
The center pin is underneath that piece. The center pin goes through the leafs, and that piece your taking about has a little hole in the bottom of it, so that the center pin will go up into it about 1/2 inch. Once you take the U-Bolts off, and lift that piece up, it will all make sense.
Old Apr 16, 2007 | 05:10 AM
locked up's Avatar
locked up
Thanks for the response. I do understand now! Go at it next weekend.
