engine swap 292 into 48 ford f-4
You just want to be sure that you get the cross pieces that the trans mounts to and you need to get the front engine mount and probably install a cross piece in the frame for it in your truck.
I am finding that I'll need to install a cross member to connect the front engine mount to in my 55 F-600. I have a 292 from a 1960 F-100 rebuilt and ready to be installed and a T-98 4 speed trans. My plan is to try to adapt an E4OD automatic eventually.
Regards,
Rick
Regards,
Rick
Thanks everyone, I have the complete 62, so I have all parts available. If I make it thru the summer I will have time to work on it this fall.. The 48 has a flathead six or I would build engine back. I like the ohead valves of the 292, they don't seem to stick as bad as the old 239, plus it will give me a little more modern engine.
raider69guy
06-24-2013 07:25 PM
79 f-150 guy
01-21-2011 06:06 PM
