Factory tach
Old Apr 12, 2007 | 07:45 PM
MarkMullins's Avatar
MarkMullins
Factory tach
Hey guys, I found a factory tach gauge cluster in one of the local yards. My '92 doesn't have one. Will it work by simply swapping the cluster in or are the provisions just not there for it? The truck it is in is a V8 truck and mine is a 4.9L. Thanks...
Old Apr 12, 2007 | 07:55 PM
andym's Avatar
andym
It depends on what year truck you took the cluster from. The provisions are there, but the wiring changed from year to year.
Old Apr 12, 2007 | 08:02 PM
lostin90s's Avatar
lostin90s
Welcome to F.T.E>
As follows are the years that work
92 -93
94-95
96
This is what will fit what with no problem . And auto or manual will fit have to swap indicators .good luck
Old Apr 12, 2007 | 08:30 PM
MarkMullins
You guys rock, thanks!
Old Apr 13, 2007 | 06:10 AM
92F150Flare's Avatar
92F150Flare
Welcome to the forum
I just did it.....not hard at all if you follow these directions and don't rush it.
https://www.ford-trucks.com/article/...Or_Bronco.html
Mine came out of a 93. I'm having a little problem with the Batt. Volt gauge but it does work and I'm sure I can fix it fairly easy...... everything else worked fine.
Try to keep your speedo needle from pegging to the right....it moves by itself as you handle the speedo......but even that came back to normal after I drove the truck and got it up to speed.
Hardest part for me was getting the cluster out......it's a tight fit until you get the wires unplugged.
Good Luck.....you'll love it
