leafspring brackets
Old Apr 15, 2007 | 03:41 AM
Chuckde's Avatar
Chuckde
Shackle Brackets. I just changed mine (F150 '96 4X2). Brackets $21 each at local Ford dealer. I replaced the shackles too (less than $20 each including tax).
I believe problem was/is poor metal/poor perp and paint. The frame they mount to is not rusted nearly as bad (different metal, better paint)!!!
Chuckde
Old Apr 15, 2007 | 01:13 PM
tgil's Avatar
tgil
i just replaced some on my dads 96 2wd, not an easy thing to do. just a tip, save your back and remove the bed, its alot easyer to get to them.
Old Apr 15, 2007 | 02:43 PM
Bugzturbo's Avatar
Bugzturbo
Say what?? It would take longer and be more work just to remove the bed than it is to do the whole hanger job. I can usually get them done in an hour (per side). Granted, that's on a lift, but on the ground shouldn't take that much longer unless you're using a hacksaw and ramps.
Bug
Old Apr 15, 2007 | 06:48 PM
tgil's Avatar
tgil
well i had to replace the hanger bracket that was rivited to the frame also. only takes about ten to remove the bed. i thought it was easyer , just my opinion
Old Apr 16, 2007 | 04:22 AM
Bugzturbo's Avatar
Bugzturbo
That's what i'm talking about, the hanger brackets that are riveted. I can't see any possible way taking the bed off the truck is less work than just doing them with it on, but to each his own I guess.
Bug
53Tow
Ford Truck Parts for Sale
Mar 23, 2014 01:56 PM
underp2
Oct 18, 2013 06:44 PM
1977f150xlt
Jun 28, 2009 11:58 PM
Mezmo
2004 - 2008 F150
Oct 1, 2005 12:40 AM
