South Carolina Chapter Join Chapter, Leader: SC_Hoaty
97 F150 4.6 AC stops intermittently
Old 04-04-2007, 10:47 AM
baileybones's Avatar
baileybones
baileybones is offline
My ac has started shutting off intermittently. I feel it surge at highway speeds and the output air starts getting warmer. I can turn the ac OFF, wait a few minutes, cut it ON and cold air returns. The clutch is not engaged when it quits. Also, using an off the shelf guage the freon pressure is at "alert".
Do I have a pressure switch problem? Is the switch replaceable without losing freon and needing recharged? Any help is appreciated.
Old 04-04-2007, 11:04 AM
TheWiz427's Avatar
TheWiz427
TheWiz427 is offline
You'd get more answers in the 1997 - 2003 F150 forum Baileybones however it sounds like it might be low on freon. Also if memory serves me correctly you have to depressurize the system to replace the pressure switch.
Old 04-04-2007, 11:07 AM
baileybones
Thanks Wiz...I'll check it out.
Old 04-04-2007, 11:19 AM
92F150Flare's Avatar
92F150Flare
92F150Flare is offline
I had an ElCamino doing that and it was the engine fan clutch.......slipping and causing the hightemp/pressure switch to cut in and out.
Wiz is right....low freon will do it too
Good Luck
Old 04-04-2007, 12:52 PM
baileybones
Thanks, I appreciate the reply.
Jlag94
2009 - 2014 F150
03-14-2017 06:57 AM
jwhopson
08-20-2015 05:57 PM
bigredtruckmi
08-23-2014 06:40 PM
ron3183
1983 - 2012 Ranger & B-Series
08-20-2013 06:57 AM
fifty-two_f1
1999 to 2016 Super Duty
15
08-22-2011 09:16 PM
Quick Reply: 97 F150 4.6 AC stops intermittently
