Pre wire brake control 2002 F250?
There should be a wiring harness under your dash just above the plug ( can't remember the exact name) that you plug in your code scanner in. It is, I believe, gray. All you need is the small pigtail to wire up your controller. Then near your rear bumper, there should be a plug there, to come off of to wire up your plug. Hope this helps.
You're welcome. This time I'll actually paste the link....
https://www.ford-trucks.com/forums/4...nder-dash.html
LOL, I found some great stuff to buy on the site it was linked to!! Thanks
