pics of lowered 67-72 ford trucks?
Old 12-27-2007, 10:09 AM
meanirishmofo's Avatar
meanirishmofo
meanirishmofo is offline
Originally Posted by Dave Severson
My '71 began it's life as an F-250, converted it all to F-100 suspension front and rear from a donor '73. Takes a bit of work to get things to fit, only difficult part was getting the right combination of springs and hangers on the rear. Pics in my gallery if you're interested.
I think I'll leave it a F250 but I'll still check out the pics.
  #92
Old 01-20-2008, 02:09 AM
tgowers's Avatar
tgowers
tgowers is offline
the front frame section is from a 71 llincoln.... the rear frame section is c-notched... and the tires are bias-ply wide whites they are called candy classics. thanks, and i am glad you like it. check out my gallery.
Originally Posted by MWaitt
That is one sweet ride. I have a stock 1966 Ford that I would like to lower as well. What exactly did you do to get your awesome truck, to that ride height? And what size tires are you running?
  #93
Old 01-20-2008, 05:48 PM
ceetwarrior's Avatar
ceetwarrior
ceetwarrior is offline
Looks cool. Gotta ask why you didn't make it a shortbox while doing all that fab work, though?!
  #94
Old 01-21-2008, 10:28 AM
jsutton's Avatar
jsutton
jsutton is offline
Because size matters! ha ha just playin' Personally I love the look of a LWB lowered.
  #95
Old 01-21-2008, 11:27 AM
tgowers's Avatar
tgowers
tgowers is offline
i agree with jsutton.... i just love the look of the long bed. i am not a fan of the short bed on the f100. i think the length makes it look much better.
  #96
Old 01-21-2008, 04:46 PM
ceetwarrior
Its just opinion, but I think it looks disproportioned when it’s THAT low.
I mean, damn, it's those guys that slam the 4-door-dually Chevy 3500's.... WTH?! Why doesn't someone slam a mid 70's F250 trailer-special truck, now that would be the ultimate ugly!!
  #97
Old 02-07-2008, 07:36 PM
griggs's Avatar
griggs
griggs is offline
how did you get it that low wondering i have 70 f100 and am looking at 3 drop i beams and 2 coils but wondering the rim size i can use for front width wise
  #98
Old 02-08-2008, 07:16 AM
tgowers's Avatar
tgowers
tgowers is offline
if you want to go as low as mine you can't do it with beams.... my buddy and i used a 1971 lincoln front frame section from the firewall forward. the rear is c-notched. the lincoln front suspension is all stock... the control arms are stock, the shocks are stock, the disc brakes are stock, the sway bar is stock... the only thing that is not stock are the front springs... my buddy had an extra set of g-body buick springs that were the exact same size as the stock lincoln springs, so we put them in...they were free. good luck. look at my gallery and you can see a bunch of pictures.
  #99
Old 02-21-2008, 09:47 AM
fitzwell's Avatar
fitzwell
fitzwell is offline
Thumbs up
Originally Posted by custom cabby
here is mine.... going for the old patina service truck look. my grandpa had a service garage in the 50's and i am planning on putting the garage name on the doors in the worn patina look
ok, how'd you do the drop on yours & what size tires are you running??
That's right where i want mine to sit
  #100
Old 12-16-2008, 08:29 PM
David Joe's Avatar
David Joe
David Joe is offline
I know that a purist would hate this, but I put a Chevy frame clip on mine, I'm about $110.00 deep with a rolling truck, centerline of wheels are at the bottom of door (It is currently a rolling chassis with cab), so when the 460 and front sheetmetal is added it ought to look real good. This clip netted me IFS, power steering, disc brakes, and is allowing me to get that 17" steering wheel out of my gut.
  #101
Old 12-16-2008, 08:44 PM
ceetwarrior
That's ok, as long as you have a ford motor in a ford truck thats all that matters.
  #102
Old 12-16-2008, 09:15 PM
David Joe's Avatar
David Joe
Thanks ceetwarrior, 460, C-6 from '86 E-250
  #103
Old 03-11-2009, 08:32 AM
72fordlb's Avatar
72fordlb
72fordlb is offline
i have a 1972 ford f100 long bed and i want to lower it im going to shackle the back or put the spring under the rear axle but im not sure what to do on the front. the truck has twin i beam front suspenion can i cut the springs. i want to slame it and still be able to turn the wheels.
  #104
Old 03-11-2009, 10:10 AM
tgowers's Avatar
tgowers
tgowers is offline
hey 72fordlb... you need to prepare yourself for the work ahead of you if want to slam one of these twin i-beam fords. There is no easy way to do it. there is no real bolt on kit to slam one of these. There have been guys on here that used drop beams, but there is some notching of the crossmember to get it down low. there are guys on here that are using crown vic clips. i used a 71 lincoln clip, but it was a lot of fabrication. if you cut the springs you will have a camber issue and there is not a lot of room between the frame rails and the top of the beams. for the rear just flip the axle and use a lowering block. good luck.
  #105
Old 03-12-2009, 09:51 AM
72fordlb's Avatar
72fordlb
72fordlb is offline
thank you. I have a friend who can air bag it for me. i really like your truck and i want to make mine like yours but mine will be black. but idk what motor im going to use.
Quick Reply: pics of lowered 67-72 ford trucks?
