I think my batteries are dying...
I left my truck parked for 4 days (almost to the minute), and when I got in it and turned the key, the gauges all pinned then dropped indicating a PCM reset. It cranked a bit slow, but turned over okay. I'm pretty sure these are original batteries (Motorcraft) so I'm sure it's time, but is this a common thing to see when they get weak? The second question is does the PCM know when they're getting weak and shut itself down when left for an extended amount of time? Just curious why it showed a reset...
Joe
Joe
if you replace the batteries, please make sure that you replace both of them... i had some trouble a few months ago.
https://www.ford-trucks.com/forums/5...-no-go-go.html
Originally Posted by nightskyisme
Mine cranked VERY slow yesterday (bad batteries) and then stopped cranking....did not do a reset here. All was fine with the new batteries. (Chevy Astros are known for alternator failure, replace it with a new, not rebuilt one) Good luck
Going through the new beast and found both the batteries to be weak. You guys get 5 years (!!??), we get 2-3 out here. I don't know, something about 120* weather.
I've always had Optima batteries, no problem with using those in my PSD is there? What is the 2nd battery for, the glow plugs?
Would weak batteries cause a "hard start". Doesn't start right up when starter is engaged. It might be normal, I might just need to get used to it.
Thanks Rocky DZL!
Thanks Rocky DZL!
I guess you could say the second batt is for GPs because after heating them up there might be little left from one batt. Weak batts will cause a hard start but only from a slow crank standpoint. If it cranks nicely, the GPR or GP system needs a look at if it will not fire.
