90 Bronc questions
My RABS seems to be disabled when 4WD is engaged. Is that normal?
If I were to remove my cats, what impact would it have on the electronics? Are there sensors that need to be removed or adjusted?
I'm leaking coolant from around the overflow reservoir cap. I was told that this is pretty common on Ford trucks. Has anybody else had this problem, and what's the fix? Not a major problem, but I'm getting tired of the smell.
https://www.ford-trucks.com/dcforum/User_files/3ab76cb342b986a3.jpg
Also, look here:
http://abcnews.go.com/sections/us/DailyNews/ford_recall001011.html
As for the coolant recovery tank weepage, I posted a query here too awhile ago and it seems that other folks experience the same; no one has an overheating problem either (although a volcanic eruption type seepage is an indicator); all of our's are just seepage, less than 1n ounce at times)
